| Home > Help Needed / General Tech Chat > clutch help A+ verto | |||||||
756 Posts Member #: 1355 Post Whore Leicester |
30th Apr, 2012 at 06:26:31pm
right i have a bit of a dilema regarding the pressure plate....
432 Posts Member #: 7856 Senior Member Essex |
30th Apr, 2012 at 06:40:54pm
Have a search for RTS, that will hold all your answers!
Edited by Amp on 30th Apr, 2012. |
30th Apr, 2012 at 06:44:04pm
an rts? sprocket is making them at a cracking price imo Yes i moved to the darkside |
1st May, 2012 at 06:12:15am
You just need to supply 2 clutches to sprocket and he supplies the rest (nuts studs spacers etc). IIRC price is £68 unbalanced and £113 balanced. Obv. If you want it balanced you need to supply a flywheel too. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
1st May, 2012 at 07:39:12am
Wats the pressure of an rts? 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
1st May, 2012 at 07:54:41am
Depends what springs you use.
In the 13's at last!.. Just |
1st May, 2012 at 08:09:49am
Enough, Andy and John used 2x998 sprrings at 21psi no worries. Audi s4 b5 - 470bhp & 486ft lbs
1st May, 2012 at 12:20:37pm
I estimate my RTS which has two std 1300 springs at about 1500lb clamping pressure, a double grey is about 1250lb, a pair of turbo springs should give about 1700-1800...
