Home > Help Needed / General Tech Chat > Max Boost with std T3 Actuator
enne
Member #: 9827
Germany
Hi Guys,
what can i get out of the std Actuator?
Normal setting is 4psi, but when shorten the rod to max?
Thanks for help.
Edited by enne on 4th May, 2012.
the standard actuator is good for about 8psi, maybe a but more with extra preload.
You would be better with a bleed valve if you want more than that
Bleed valve will allow 15psi+ with standard preload.
enne
Member #: 9827
Germany
Thanks alot.
