| Home > Technical Chat > how to work out if its any good? | |||||||
831 Posts Member #: 908 Post Whore gateshead |
5th May, 2012 at 03:33:45pm
how do i work out if this new turbo i have bought will be any good on my motor? balls to the blower!!!
5th May, 2012 at 06:45:25pm
Forts thing to do is find the a/r ratios of the snails. On Garrett's they are usually cast or stamped somewhere.
5th May, 2012 at 07:07:58pm
Work out what your estimated power will be in air flow, Lb/Min. Then find a compressor map for the turbo you have, and if you cannot find one, find the next nearest for a gestimation. See if the air flow your engine needs falls somewhere into that map. this will also tell you how much boost you will likely need to run.
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
5th May, 2012 at 07:15:21pm
how do you work out lb/min airflow? one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
5th May, 2012 at 08:30:32pm
There are several 'calculators' available on the internet, but you do need to know a few basic things about your intended engine combination.
5th May, 2012 at 08:43:46pm
Not straight forward then, I'll try and get my head round it and have a google as well, cheers one day boost will be mine!
5th May, 2012 at 08:50:16pm
http://www.engineeringtoolbox.com/flow-uni...rter-d_405.html |
5th May, 2012 at 08:51:04pm
i JUSt found this, did some calcs on it and im confused haha
6th May, 2012 at 09:52:01am
If you want to do the compressor maths, then this may help:
6th May, 2012 at 08:41:25pm
hmmmm. that doesnt sound good. especially as quick engine spec is morspeed head with 24cc chambers, 1330cc, roller tip rockers, cast omega 11cc dish pistons, lightened crank, sw5 cam, s/c box and drops, xpin diff and 3.44 fd. was kind of hoping this would be ok. especially as all the ports on it seemed to face the right way. balls to the blower!!!
6th May, 2012 at 09:49:34pm
bearing in mind, i only want about 150bhp si i can actually use it and drive the bloody thing rather than it be sat in the garage for another 3 years. balls to the blower!!!
7th May, 2012 at 06:40:57am
if its the 452283-0003 ,then its off a 135 bhp diesel .using roberts 2/3rds diesel rule ,that will work up to 202.5 bhp .
Edited by robert on 7th May, 2012. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
7th May, 2012 at 07:38:39am
yeah it is the 452283-3 one. the advert says rover 25 but the part number is 452283-3.
7th May, 2012 at 08:14:21am
I like this rule. Lets hope you don't want 202.6bhp though!
On 7th May, 2012 robert said:
if its the 452283-0003 ,then its off a 135 bhp diesel .using roberts 2/3rds diesel rule ,that will work up to 202.5 bhp . it runs as stock at 19.9 psi in the mg zr .on the rover 25 it runs around 17.5 psi stock . FIT IT ! Edited by wil_h on 7th May, 2012. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
7th May, 2012 at 09:13:52am
er.....nope. 150ish will do me fine. lol
7th May, 2012 at 09:47:03am
On 6th May, 2012 turbochargedstu said:
hmmmm. that doesnt sound good. especially as quick engine spec is morspeed head with 24cc chambers, 1330cc, roller tip rockers, cast omega 11cc dish pistons, lightened crank, sw5 cam, s/c box and drops, xpin diff and 3.44 fd. was kind of hoping this would be ok. especially as all the ports on it seemed to face the right way. Perfect engine for a GT1752 :) Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
7th May, 2012 at 10:35:39am
On 7th May, 2012 turbochargedstu said:
er.....nope. 150ish will do me fine. lol for now... On 11th Feb, 2015 robert said:
7th May, 2012 at 10:46:42am
I'm not sure I follow this diesel vs petrol arguement.
7th May, 2012 at 11:26:03am
hmmm. something doesn't add up. just looking at the turbo, the shell and compressor all looks shiney and new but i look into the exhaust end and there is definatly signs of carbon and use. sold in the advert as brand new never fitted to a vehicle!! balls to the blower!!!
