Home > Help Needed / General Tech Chat > turbo/mg/276 cam
Dangerous
Member #: 417
which would be the best for a engine running standard pistons,intercooler and maybe a vmax group a head*tongue*
Think the 276 is a kent megadime
forgot to mention no traffic jams round here
Edited by Dangerous on 13th May, 2005.
My mate had a 276 in his Turbo a few years back and it was a great little motor, slightly lumpy especially with low compression, but nothing extreme. It pulled strongly from quite low down, though he did have a T2 fitted.
The NA MG Metro cam will be very driveable indeed. If your not bothered about perfect road manners i'd go with the 276 !
Oh you running 1.5 rockers ?
Phil. *smiley*
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
HI , 276 have n/a lca, I would recommend to use the mg mety cam, or best the phase 2 cam from avonbar, but what the cam need is a mid cam inlet (piper270/kent266/vp2 etc), and a fast road cam exhaust (285/286/etc) at 108 lca...this make a very drivable cam and help the exhaust gas to exit, and still have a lot of inertia to spin the turbine wheel
for info, ph2 cam is 22/62in 76/36 ex (264°/292°) (lift 0.350/0.390)
full lift at 110°
fab
turbo hogster
Member #: 178
stowmaket suffolk
t3tone fitted a 276 to his 1380 and goes bloody well, but lumby on tick over but turbo spins up quickly and comes out at a impressive 168 bhp on 12 psi, so go for it, but dont no what it would be like in a 1293 though.
dan
Member #: 93
it sounds a bit strange saying this but has anyone mixed 1.3 & 1.5 rockers ie. put the 1.5's on the exhaust and the 1.3's on the inlets??
T3Tone
Member #: 252
Sunny suffolk
I use the 276 along with 1.5 rockers so would have thought using it in a 1293 with 1.3 rockers would be a very good cam, or maybe 1.5 if not bothered about tick over. But alot of the time what seems to work for one engine wont in another!!!
Like Dans point on mixing rockers, be interesting to know if people have tried this and what the results where??
-MINI CLUBMAN 1380 TURBO-
turbo hogster
Member #: 178
stowmaket suffolk
i dont think it would tone as the pillars would be different and the geomomtry would be out but having said that ive got a set of 1.5 stipped to bits at the moment i might just mix them up and see what happens . but i think for the 1.3 they would be to far away from the valves at a guess.
Also I think using the 1.5's on the exhausts and 1.3's on the inlet would give you some increased exhaust valve "area" however it would also increase the overlap of exhaust relative to inlet too much IMO to see any benefit.
I've thought about the 'mixing' before also! Too much work as hoggy says!
fab
Member #: 100
Paris\' suburb
the phse two with his 0.390 lift on exhaust side is in the ballpark, and work bloody well , why bother with other timing ? any cam can work with a turbo engine untill it haven't too much timing on the inlet, but there is the set up which works, other which works a little more, and the last which are working at their best, a 276 is definitely a non turbo cam , it isn't because the 276 have power potential , that a special turbo cam will not beat it
