Home > Help Needed / General Tech Chat > starting
Bertie the dirty mini30 has an odd starting problem
when cold it will just spin over without a hint of starting yet it will bump start very very easy and sit and idle no problem
if its hot it starts on the button
any ideas
Mini_Andy
Member #: 432
i had this same problem, changed the dizzy cap n rotar arm and sprayed some danp/cold start stuff all over the engine bay.
happy dayz
Check the 12V feed to the coil when starting. As it's a ballast resistor system it should have a seperate 12V supply when cranking. It's a wire direct from the solenoid.
If its below (say) 6V when cranking you're probably not getting the 12V supply and the coil will be struggling.
Wil
Dangerous
Member #: 417
I would say the same as wil h,are you still using the same dodgy battery.....may have a duff cell
brand new bosch one mate
was the rotor arm it had become loose on the shaft replaced and it starts well now
