Home > Help Needed / General Tech Chat > turbo inlet size
TurboMike1992
Member #: 9928
Hartley, Kent
Hi there, just a quick question, was just wondering what the standard size diameter on the garrett t3 for my engine i just brought should be, got a friend telling me it should be 63 mm but i had a measure up and it works out to be 57mm so im slightly confused, if anyone could shed abit of light on this for me it would be much appreciated, Cheers
Low boosting for now.
Garret T3 is a "generic" statement.
The T3 refers to a "frame" size but the actual compressors/turbines vary a lot across the range.
The T3 on my Cossie has a much bigger set of inlets/outlets than my Metro T3.
Standard Metro T3 is 57mm as you measured.
TurboMike1992
Member #: 9928
Hartley, Kent
ahh i see yes, cheers for that, my friend rang me too and realised that his sierra, just a pity really because i could have saved a small fortune on silicone hoses and stuff *frown* nevermind, going turbo is never a cheap option. thanks again buddy.
bennyy
Member #: 9037
Doncaster, yorkshire
Are you talking about the up pipe where the intercooler hoses go? If so its 51mm.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Outlet is 51mm on the Metro derived T3 but the inlet is 57mm.
The clue is in the question title :)
bennyy
Member #: 9037
Ignore
Edited by bennyy on 9th May, 2012.
