Home > Introduce Yourself > hi.
stockport1
Member #: 9929
ive been building mini turbos since around 1994.
current model is nearly repaired after sitting for 6-7 years on the driveway.
car:
Exterior:
1989 red mini.
13in revolution rfx
interior :
6point cage welded in.
oil pressure gauge + 2 x grey escort rs turbo recaros minus frames bolted to floor.
suspension:
front : poly bushed, turbo brakes + calipers, coil over spax minus coil springs (too stiff)
rear: spax,hilo,neg camber brackets,minifins etc ..... the usual :)
engine:
mg metro turbo.
*GENUINE* leyland 649 race cam.
mg head with turbo exhaust valves/guides etc and homemade porting.
modified plenium (std dumpy welded up) - aftermarket dumpy fitted.
intercooler off rover diesel -cant remember which one. :)
2 core rad.
mini sport 4 speed sc box + transfers
mini sport X pin diff
grey clutch + race plate + lightened flywheel and backplate
bob weights welded up in dizzy on a race cam - (see vizard - tuning a series )
Boost - ? whatever i damn well feel like ...upto 25psi on a cat and fiddle day racing the bikes.
bhp - no goddam idea...about enuf at 18 psi i reckon.
GUYS - u really need to be putting celly paint thinners (toluene/xylene) in your fuel.
melted pistons - no more
melted head gaskets - whats that.
I have problems with my goddam carb freezing!!!!
Can get 5-10 miles before - cough splutter....cuts out...wait 5 mins to defrost...then off again.
Even after a thrashing the engine bay is COLD!!!!
i mean like ...luke war at most on the block!!
Instructions:
Put in 100% toluene/xylene
advance timing till it kicks back turning over...
ease off till it fires....sorted.
(thats with the bob weights welded up in dizzy on a race cam tho)
Hello and welcome
Hi!!
Edited by Brett on 8th May, 2012.
wng691s clubby
Member #: 9252
Cleethorpes
welcome
Done now needs redoing lol
lee.pb
Member #: 9199
Lancashire
Welcome *happy*
A warm welcome!
1380rich
Member #: 9766
Warwickshire
Hello and welcome *happy*
Avon 2010 class c 3rd
maccamcvey
Member #: 6673
Worral Sheffield
hello there
