Page: |
Home > 998cc > exhaust manifold | |||||||
49 Posts Member #: 8462 Member |
8th May, 2012 at 08:55:50pm
my first atempt at making a manifold for my 998 turbo looked ok but has cracked in 3 places after less than a 1000 miles. i used a old LCB and a mig welder to make it, any suggestions on how i could make it better/ stronger??? thanks neil |
8th May, 2012 at 10:00:15pm
do you have a picture of it? |
![]() 126 Posts Member #: 9515 Advanced Member ireland |
8th May, 2012 at 10:00:30pm
Try this link.
A job worth doing is a job worth over doing |
![]() 36 Posts Member #: 9909 Member Tyler, Texas |
9th May, 2012 at 12:36:00am
Sounds like more of a welding issue than a design issue, would need pictures to confirm but probably just not enough penetration. -1974 Mini 1000 - BRG Turbo Build Soon to come
9th May, 2012 at 06:55:43am
Also the materials used where probably not up to the job. I doubt an LCB was designed to bear the load of a turbo on it. Edited by apbellamy on 9th May, 2012. On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it ![]() |
9th May, 2012 at 07:48:19am
A little bit of searching on here will reveal that using an LCB as the ex. manifold with a turbo will result in it cracking.
![]() 8604 Posts Member #: 573 Formerly Axel Podland |
9th May, 2012 at 11:40:22am
I've been working on my new manifold this morning:
9th May, 2012 at 05:42:14pm
thanks guys! i have been to a local exhaust fitting garage today and they can get a meter length of tude that is 1.6mm wall thickness, will this be better? and what diameter will i need? |
Page: |
