Home > Help Needed / General Tech Chat > roller rockers
jameswildcooper
Member #: 1355
Leicester
im on about standard rockers.....
so which type are better?
the later type ones or the early forged ones like these?
shellspeed
Member #: 9580
Surrey
They are pressed steel ones. I read somewhere (poss calver feature in mini mag) that the other type are less prone to wear.
The pressed steel type (pictured) are closer to 1.3:1 than the later sintered type.
The forged 1.5:1 are pretty rare and expensive so youre better off getting roller tipped if you wanted 1.5:1.
Alex
Member #: 1851
Woolavington, Zummerzet
I run the pressed ones (as pictured) wherever I can - they have a marginally better ratio and can be rebuilt.
jameswildcooper
Member #: 1355
Leicester
hmmm i have some pressed one lying about might put them on then....
The pressed steel ones are 1.295 ratio and are good make sure the shafts not worn out on them,
Yo-Han
Member #: 3228
North of the Netherlands
I heard people run a small weld over the top of the presse steel ones to give these a bit more strength?
Dazed and Confused....
madminimart
Member #: 4373
Yeovil, Somerset land
I have a set of these, tho just replaced my head gasket and don't fancy doing it again just to fit these rockers.
Why would you have to replace your head gasket to replace the rockers?
Ive reused fairly new head gaskets before with no problems.
eden7842
Member #: 8852
leicestershire
Got a welded set on the misses 1275 made a heap of difference from the stock 1s
