| Home > Help Needed / General Tech Chat > Turbo Timing max | |||||||
79 Posts Member #: 9827 Advanced Member Germany |
9th May, 2012 at 12:59:41pm
9th May, 2012 at 05:43:33pm
Standard dizzy for economy is 28 Max advance. ...... but depending? On your engine spec its between 19 and 24 degrees. To safegaurd your engine. ......in general.!!!!!!
9th May, 2012 at 08:02:07pm
10th May, 2012 at 08:18:47am
If your running standard boost and standard compression I would set to 25deg, obviously I take no responsibility if it goes bang. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
10th May, 2012 at 08:23:50am
Thank you.
10th May, 2012 at 08:36:55am
Depends to what extent you are talking. But in general more boost = lower compression + less advance.
10th May, 2012 at 08:46:40am
For example, a couple of years back I ran 12psi on 8.3:1 on 25deg. with a cosworth 2wd intercooler, and it was fine, although it was winter and air temp was lucky to be 5 or 7degrees.
10th May, 2012 at 09:10:58am
Ahh, i understand.
10th May, 2012 at 12:51:18pm
less CR = able to run more advance,
Yes i moved to the darkside |
![]() 517 Posts Member #: 9931 Post Whore brighton |
10th May, 2012 at 07:58:47pm
on a std engine running 8:1 cr with 18 psi what timing ?
10th May, 2012 at 08:17:44pm
On 10th May, 2012 charlieb150 said:
on a std engine running 8:1 cr with 18 psi what timing ? and when do you set it ? sorry for the silly stuff but fairly new to turbo a std engine with 8.1CR is very not standard 18 psi is very not standard you cant guess figures like that.. my answer is get on a dyno where the operator knows what he is doing Yes i moved to the darkside |
10th May, 2012 at 08:30:00pm
start at 18 deg and work forward, but make damn sure your rich enough! On 28th Aug, 2011 Kean said:
