| Home > Beginners Tech > Drop gears, gearbox and final drive | |||||||
53 Posts Member #: 9508 Advanced Member Bromley |
10th May, 2012 at 10:03:57am
Im still collecting parts for my gearbox, although I've only got to buy the diff now. I've just bought some straight cut drops off eBay, however I don't know of they'll fit my spec or not.
10th May, 2012 at 10:19:44am
Go with at least a 3.2 or 3.1. 3.44 and you wont see much benefit from the turbo as you need to load the engine up to get the turbo spooling. As for the drop gears the early idlers had a smaller shaft, I believe you can covert the transfer box to the smaller early type. Id double check this mind as its only from memory. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
10th May, 2012 at 12:46:55pm
3.44 is the lowest i would go on the road make for a lively drive without screaming its tits off but is a little slow on the motorway
Yes i moved to the darkside |
10th May, 2012 at 12:50:47pm
I've got a 3.1 and 12's (SCCR Clubman gearset) on my clubby and I think its a fraction too tall. I would have preferred a 3.2. If something is worth doing, it's worth doing half of. |
10th May, 2012 at 01:20:25pm
I have a 3.2 to go in my box. s/c box with abingdon ratios and 10s. looked the best compromise on guessworks ratio calculator On 11th Feb, 2015 robert said:
10th May, 2012 at 02:48:04pm
I've just changed from a 3.1 with ST SC box and 13" wheels to a 3.44 with Clubman evo box and 12" wheels.
In the 13's at last!.. Just |
10th May, 2012 at 03:04:36pm
It's only about 500rpm difference between 3.1 and 3.44 FD at 70mph, so I went for 3.44. Better ratios for just about everything except motorway, and with straight cut drops, I'm not using motorways much! As with a lot of others, it's not a daily driver. |
10th May, 2012 at 03:42:35pm
Thanks for clearing that up! It's just hard to choose that's all, I'm looking for it to be pretty nippy round town but able to handle the odd motorway journey for shows etc.
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
10th May, 2012 at 03:47:44pm
I've got a 3.44 and a T3 turbo on a 1380cc and I'm on full boost just over 4k.
