| Home > Help Needed / General Tech Chat > non a-series Throttle body vac take offs? | |||||||
656 Posts Member #: 1917 AKA chargedzetec Milton Keynes |
11th May, 2012 at 06:02:12pm
I have ITB's on my Zetec Turbo engine.
This is FORD country, on a quiet day you can hear Vauxhalls rusting. |
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
11th May, 2012 at 06:05:22pm
my logical thinking says no, as there will be no vacuum to read when then valve is shut and no air flow. it mentions on the autosport lab site for the megajolt set up to run individual lines to a collection box and take feeds from there. iirc Edited by wez on 11th May, 2012. one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
11th May, 2012 at 06:10:31pm
All four need to be connected together then just on take off to whatever you need it for. If you do not join them all together the average vacuum will be lower On 26th Oct, 2004 TurboDave16v said:
11th May, 2012 at 06:17:54pm
thats what I thought, cheers This is FORD country, on a quiet day you can hear Vauxhalls rusting. |
11th May, 2012 at 06:37:51pm
you may struggle to get a decent vacuum reading either way.
11th May, 2012 at 07:08:09pm
I run a tps on a specialist components ecu, and will get it setup there. I'm fairly sure that's how it was mapped before?! This is FORD country, on a quiet day you can hear Vauxhalls rusting. |
