Home > General Chat > ratios drops and FD
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
im after a real fast pick up so was thinking of using a 4.67:1 seamy CWP 1.136:1 drops (Prim22 idler30 in put25) SCCR clubman set
from what i can work out it will top out at 141kph (87.8MPH) 8K or 100kph at 5461rpm any thoughts? a tad to nuts?
link to the ratio calculator i used http://ctny.audiworld.com/mark/s4/gears/gear_calc.html
Edited by Turbo This.. on 12th May, 2012.
What engine?
If turbo, this would be rubbish.
Carl S
Member #: 1761
Stalker
I think you'l get very bored of the engine screaming when you want to go any faster than 50mph.
11mph/1000rmp in 4th is bonkers.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
175 50 13 = 61.5" measured
its a 1098 NA
jamie@thefatgarage
Member #: 9345
Sheffield
It would be perfect for driving round a car park, as long as it wasn't a supermarket.
with straight cuts aswell? you sir are bonkers
on the plus side if you generally cant be arsed to change up and down gears just stick it in 4th and potter about town
In aussy land go for standard ratio drops with 3.2 final drive! As you have so many open roads will suit your N/A 1100 engine
A good ballance I think............ other oppinions may varie. ?
Edited by BENROSS on 12th May, 2012.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
well it was just an idea i do want a super fast throw the gears car but your right im bonkers its way to low and besides im lot paying near 600 Aussie bucks for drops..
think ill go with a 3.764 FD sc 1:1 drop
edit noise dose not bother me it eggs me on !
Edited by Turbo This.. on 13th May, 2012.
3.7 is a great diff for what you want and still useable.
