| Home > Help Needed / General Tech Chat > caster | |||||||
12th May, 2012 at 07:59:09pm
So my car torque steers like a bitch. I know that I need to probably replace the plate type LSD with an ATB and get some wheels with less dish..
12th May, 2012 at 08:12:15pm
Personally with a plate LSD I'd resist running more caster. You really need to know what it is at the moment before you think about changing it. And measureing from the subframe is never reliable, my car is equal side to side, but the bottom arms and ti-bars are not the same length.
12th May, 2012 at 08:12:47pm
I've got one of those cheepo magnetic camber/caster gauges you can borrow if you like. On 11th Feb, 2015 robert said:
12th May, 2012 at 08:15:38pm
Jamie, do you have any rubber in your front suspension?
12th May, 2012 at 08:25:02pm
Carl, Not rubber, it's all poly bushes as opposed to rose joints.
13th May, 2012 at 07:29:29am
On 12th May, 2012 jamie@thefatgarage said:
Carl, Not rubber, it's all poly bushes as opposed to rose joints. Wil, cheers, that sounds like a fantastic offer. I'll be in touch sometime before Avon. Got to fix a couple of other bits before driving too far from the garage! No idea on the ramp angles, it's an ebay special salisbury one that I got in a gearbox, figured it was worth a try before spending £££ Andy, a good idea. Worth getting an idea if it's miles out as it is. I'll be in touch this week. |
13th May, 2012 at 08:56:47am
As Carl says, the movement in the suspension is the problem. I had the same issues until I changed to all rod end suspension. Also try reducing your front toe setting I seriously doubt it! |
13th May, 2012 at 12:55:34pm
Andy, a good idea. Worth getting an idea if it's miles out as it is. I'll be in touch this week. We're going away 10am Monday morning, back late on Sunday. The mother in law is dog sitting so I can leave it with her if you can't get over before we go... On 11th Feb, 2015 robert said:
