| Home > General Chat > eboost2 boostcontroller | |||||||
![]() 190 Posts Member #: 8935 Advanced Member netherlands |
15th May, 2012 at 07:17:06am
Has anyone any good experience with this booscontrollerer? And would it be wort the money??
15th May, 2012 at 08:20:29am
Our gerts bro has one on his 500+ nana 200sx says it gives rock solid boost control. If something is worth doing, it's worth doing half of. |
15th May, 2012 at 09:24:40am
I've used a few turbosmart ones and they are great. I've since moved to using a Gizzmo MS-IBC which is just as good, and half the price. |
15th May, 2012 at 06:59:24pm
Have you any links James
15th May, 2012 at 07:36:11pm
The unit info is here
15th May, 2012 at 07:41:04pm
The bit it doesn't make clear in the info is that you can have 6 pre-set boost levels and a remote button to cycle through them, so I have a button on my steering wheel and can select boost per gear if I was that sad. Well I could if I connected the wire back up after having the steering column off the other day anyway.. |
15th May, 2012 at 08:13:33pm
Looks good James and reasonably priced for what in it
15th May, 2012 at 08:46:23pm
On 15th May, 2012 jamie@thefatgarage said:
The unit info is here http://www.gizzmoelectronics.co.uk/Product_MSIBC.html I got mine off ebay for just under £200. Crystal Sound Audio said:
