Home > Ebay items For Sale > ported cylinder head
metrovan88
Member #: 9581
blackpool
got this for sale on ebay if any one is interested?
http://www.ebay.co.uk/itm/Mini-Metro-A-ser...=item4ab79343ec
If you are going Turbo, why not whip another 1cc out of the head and use 18cc dished pistons.
At +0.020 this is around 8.5:1.
metrovan88
Member #: 9581
blackpool
ive already got my block as i want it really as i was able to get hold of a rebuilt block with standard turbo pistons. dont really want to be buying new pistons and getting bores enlarged when i have a suitable block at the moment. when all i need is a head with larger chambers
i could pop you in the chambers up to 26cc pm me if you want to go down that route, would save you a lot of money
There's no way you'll get 26cc out of the chambers if it's been skimmed & they're currently 19cc. *happy*
metrovan88
Member #: 9581
blackpool
yeah i was going to get one of you too enlarge them for me as i like the head but like phil says dont think itl be possible. i took it too a local machinist and he reckons 3-4cc additional at max
Edited by metrovan88 on 17th May, 2012.
I'd agree with that. I'd say 3cc was pretty likely.
metrovan88
Member #: 9581
blackpool
i believe that standard turbo pistons have a dish of 12cc is that correct?
therefore i will need chamber size of around 25cc then. il just have to wait for a more suitable head to come up.
Yes 12cc. With 25cc in the head you'll be around 8.6-1
lathe a bit out of the pistons?
metrovan88
Member #: 9581
blackpool
Well thought about that but dont really want to ruin the integrity of the pistons
You don't like solving stuff, do you?
tadge44
Member #: 2500
Buckinghamshire
I have machined out standard turbo pistons and have no problems so far.
metrovan88
Member #: 9581
blackpool
No i do like solving things but have been advised to not dish out my pistons and instead just get another head. How large have you had them made. I would need another 6cc out of them both collectively
bennyy
Member #: 9037
Doncaster, yorkshire
If you want a new head,get a new head, I'm the same as you by the sounds of it, once its in my head there's no changing my mind.. lol
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
tadge44
Member #: 2500
Buckinghamshire
IIRC correctly they were out to 14cc but Sprocket can confirm, as he did them.
There is lots of metal left at that size.
Edit: dam predictive texts
If you have set your sights on what you want then there no altering your train of thought
Dishing the pistons are no problem!
Deep chambered heads done on the Bridgeport and blended could easy get another 3 to 4 ccs in
there, plus the 3 been mentioned!!! . ..... so 25 cc is a total reality.
Hope this helps, . . . positive thinking is what's needed *happy**happy*:-
Edited by BENROSS on 18th May, 2012.
