Home > Technical Chat > Supercharger pully
page90jack
Member #: 9951
BRIGHTON
What's the best size supercharger pully to use on a 1330?
depends how much boost you want to run. for suck through with an M45 any more than 7psi and you just make more heat...
Andy500
Member #: 2443
Cheshire
What size is the crank pulley? And as Anyd has said, what boost do you want to achieve?
The Standard pulley will most likely give you more boost than is efficient.
thefro1991
Member #: 9385
i calculated for my uni assignment that for a 1310 engine, at 6000rpm, the standard charger pulley is 65mm in diameter, the crank pulley needs a diameter of 104mm to give optimum efficiency at 10psi
