| Home > Help Needed / General Tech Chat > OK then what would you suggest?? | |||||||
46 Posts Member #: 171 Member Portsmouth, Hampshire |
16th May, 2005 at 03:14:42pm
I have re-built my carb. and re fitted it to my car. I found a great big hole in the air line that comes off of the brass insert in the compressor housing, the pipe that went to the boost solenoid. |
16th May, 2005 at 04:13:45pm
What I would do is either drive it VERY gently or get a mate to tow you on a rope to your nearest MOT centre. There is bound to be one quite close to you if you live in a town. Then get them to put the car on their gas tester machine, and set the idle CO to approx 3.5%. Then set up the idle speed using the adjuster and it should hopefully be somewhere approximately near, at least good enough to get you gently to the rolling road on low (no?) boost.
17th May, 2005 at 09:17:55am
I cant even get it to run without stopping if a hit the accelerator at the mo so might have a bit of a go with the mixture. I am a bit worried I have done some thing wrong!
17th May, 2005 at 09:52:06am
Have you tried putting the pipe with the big hole in it back on? i.e. as it was before, I assume it ran ok then?
17th May, 2005 at 10:39:50am
I dont understand why I should do that?
17th May, 2005 at 04:30:37pm
The set up method gives you a basic mixture setting. It is something like screw the mixture screw all the way in then back it of so many turns. I can't remember how many off the top of my head but have a careful read through the rebuild kit instructions it is in there somewhere.
17th May, 2005 at 09:32:56pm
As regards getting the mixture something like right - this'll get u started:
Edited by turbodave16v on 17th May, 2005. On 17th Nov, 2014 Tom Fenton said:
23rd May, 2005 at 10:44:31am
Hi, I have done the things you suggested TD and I must say it is not quite right but it feels good to drive now that i have remedied the air line side of the system. I am only boosting a small amount now like you are supposed to with the stock actuator. But the whole drive seems so much smoother and the boost picks up progressively.
23rd May, 2005 at 11:22:02am
i'd definately fit the cooler before the RR, then you can adjust the boost up while ont he rollers. On 20th Oct, 2015 Tom Fenton said:
23rd May, 2005 at 11:29:57am
Great, I'll start working on the fitment of the cooler asap! Is it ok to use a bleed valve to up the boost or is it best to get a new actuator?
23rd May, 2005 at 01:36:15pm
Bleed valve will be fine.
23rd May, 2005 at 04:09:33pm
I think I may go down the MBC route after reading about them on this site, is this ok?
23rd May, 2005 at 05:17:30pm
Bleed valve, MBC, whatever - it's boost that makes power, not the prettiness of either or the ebay selling jargon... On 17th Nov, 2014 Tom Fenton said:
24th May, 2005 at 09:26:30am
Sorry! just didnt want to waste my money on something that is a lie or crap!
24th May, 2005 at 02:49:12pm
Know what you mean...
