| Home > General Chat > rubbish fuel | |||||||
19th May, 2012 at 03:11:15pm
Yesterday i filled up the Va-stead at an asda petrol station, the car now is a gutless peice of poo now, a little anoyed as i have a full tank of this stuff now, i forgot how bad asda's fuel is compared to sainsburys.
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
19th May, 2012 at 03:56:47pm
octane booster? or is it a diesal?? On 10th Mar, 2012 theoneeyedlizard said:
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
19th May, 2012 at 04:33:16pm
Asda fuel made my 1275 stage one run like a 3 legged donkey, that's how bad the stuff is.
19th May, 2012 at 05:57:47pm
Get what you pay for.
Edited by Sprocket on 19th May, 2012. On 26th Oct, 2004 TurboDave16v said:
19th May, 2012 at 06:19:42pm
I run the volvo on asda fuel most the time as there is a station 30 seconds from work but there is a masive differance compared to shell asda is shite but morrisons stuff is still worse lol Yes i moved to the darkside |
19th May, 2012 at 07:06:00pm
I,m not sure how much of this comment is subjective, because fuel is distributed in a way that many fuel stations are receiving the same fuel, even though it is retailed under different names.
19th May, 2012 at 07:35:33pm
If its deisel Paul put 10 liters of paraffin in
19th May, 2012 at 07:50:08pm
i try not to use supermarket fuel for the same reason.
19th May, 2012 at 08:05:28pm
Just because it comes from the same refinery does not mean that it is sthe same at Asda, that it is at Shell.
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
19th May, 2012 at 09:02:46pm
I can tell where I've filled mine up and I never use supermarkets. If I use the local murco station it runs shit, if I use bp it runs a bit better and if I use shell it runs better still, and shells the cheapest as well. Win win really. one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
19th May, 2012 at 09:30:06pm
I found Sainsburys fuel is pretty good and relatively cheap. I think (and don't quote me on this) that BP supply the fuel for sainsburys. On 26th Jan, 2012 Tom Fenton said:
19th May, 2012 at 09:30:53pm
the shell here is about 5p more expensive vs supermarkets but over a full tank and the slighly better milage probably works out cheaper, Yes i moved to the darkside |
19th May, 2012 at 09:46:04pm
well im going to fill my daily up tomorrow with adsa diesel, and see what i get to a tank.
My build thread..
19th May, 2012 at 10:29:50pm
Sains use esso fuel which is why i normally get fuel from there but asda is on the way home Drives
20th May, 2012 at 09:30:33am
sainsburys may well use esso fuel but it will not be what you buy at the pumps at an esso station
On 19th May, 2012 Paul R said:
Sains use esso fuel which is why i normally get fuel from there but asda is on the way home |
20th May, 2012 at 10:09:00am
i always use shell optimax in the mini and i always use normal shell in my other car. ive never had any problems and for some reason the shell in burnley was selling it for £1.31 a litre |
20th May, 2012 at 10:12:33am
Can't say I've ever noticed in the van, but in the mini I religiously used v-power. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
250 Posts Member #: 1615 Senior Member Ferndown, Dorset |
20th May, 2012 at 10:31:20am
my 1380 n/a i always use high octane, runs like turd on normal stuff. its not fussy which brand it has although v power makes it run a touch smoother. my daily e36 328 bmw i always run v power in that if i can, if i cant get it il use another high octane brand, and i certainly notice the difference in terms of mpg's and general running between them, v power giving me a couple more mpg's and being more responsive On 1st Mar, 2009 MikeRace said:
Hmmm weberyyy On 21st Apr, 2009 madcatminis said:
I hope she's got knickers on or you'll have a funny runny mark on your bonnet. Quite like what a snail leaves behind. |
20th May, 2012 at 12:09:05pm
On 20th May, 2012 Johnny said:
i always use shell optimax Not used the mini in a while then Optimax was last seen in the UK in 2006/ 2007
20th May, 2012 at 04:13:18pm
I have done over 20,000 miles in two common rail diesel engined cars over the last year, and nearly all the miles on exactly the same journey between North Wales and Yorkshire. I have used mainly either Asda or Shell diesel, and sometimes Tesco. The only thing that changed the MPG significantly was ambient temperature or high winds. Two weeks ago I acheived 43 mpg average with the cruise control set to 60 mph on my journey to Yorkshire, and last week on the same journey at the same speed I got 50 mpg average. The only difference was miserable wet cold weather on the first trip and dry warm sunny weather on the second. This pattern in change of MPG occurs with every change of weather I experience, with cold wet weather dropping mpg and warmer weather lifting it, and it occurs regardless of brands of diesel. Based on my experience, trying to assess the different between Brand X and Brand Y on the open road is next to impossible.
20th May, 2012 at 10:31:21pm
Denser air so more fuel required? I run a supercharger and I don't care the TB is on the wrong side.
20th May, 2012 at 11:06:37pm
on the volvo a few monts back i had a sticky stat, wouldnot go over 80degc, mine to york was 14.somthing to the gallon @ 50mph 2 weeks later exactly the same journey but with a new 92deg stat again at 50 (same driving style because i wanted to compare) it did 36 t' gallon and thats not driving like a granny and its not motorway either Yes i moved to the darkside |
20th May, 2012 at 11:09:37pm
how relevant that is to the thread i have no idea lol
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
21st May, 2012 at 10:31:08am
I always use Tesco petrol, 95 in the daily drive and 99 in the Mini.
21st May, 2012 at 09:02:02pm
haha yeah optimax. sorry my memory is a bit bad sometimes. i meant v-power... :)
