Home > Help Needed / General Tech Chat > The boost against CR graph
Simon
Member #: 1865
Norwich, Norfolk
This graph has made a few appearances on the forum:
However, how religiously should you stick to it?
For eg, if you had a CR of 9 the graph is showing around 12-13psi, but what if you wanted to push up to 15-16psi as so many do?
Does the graph take into account intercoolers?
Put it this way we ran 25psi on 8.15:1 that graph seems to sat a max of 16-18psi.
I'd be quite happy putting 15psi through and engine with 9:1 as long as it has mappable ignition and a decent IC.
That graph was very conservative when I produced it in the first place.
In hindsight, it is basically incorrect above 15 psi.
EDIT: Original thread:
http://www.turbominis.co.uk/forums/index.p...tid=124316&fr=0
Edited by Paul S on 21st May, 2012.
tadge44
Member #: 2500
Buckinghamshire
This will encourage me to push my car to 18psi this year !
You are a mad man Dave *smiley*
Good skills.
