| Home > Help Needed / General Tech Chat > How to wire multiple spot lamps on seperate switches ? | |||||||
![]() 481 Posts Member #: 7893 Senior Member Portsmouth |
21st May, 2012 at 06:12:53pm
Hey all
Edited by Wile E. Coyote on 21st May, 2012. My 79 Clubman Build Thread - http://www.turbominis.co.uk/forums/index.php?p=vt&tid=451008
264 Posts Member #: 8853 Senior Member Bristol |
21st May, 2012 at 07:11:12pm
You would be better off running them off completely different circuits. |
21st May, 2012 at 07:23:04pm
two circuits and dont forget the relays!
21st May, 2012 at 07:34:34pm
Cool, ok lads, cheers.
21st May, 2012 at 07:46:34pm
What is the difference between the 4 and 5 pin relays ? My 79 Clubman Build Thread - http://www.turbominis.co.uk/forums/index.php?p=vt&tid=451008
21st May, 2012 at 08:19:34pm
Does this look better ?
21st May, 2012 at 08:29:14pm
careful, there are two types of 5 pin relay. There are 'changeover' relays which have both normally open (NO) and normally closed (NC) contacts, and then there is the 'double feed' relay wich is normally open, this has two common load pins and one battery pin. Both look the same, but differ. That said, forget these for now.
21st May, 2012 at 08:30:34pm
^^ Looks better
21st May, 2012 at 08:32:43pm
Thanks Sprocket, appreciate it My 79 Clubman Build Thread - http://www.turbominis.co.uk/forums/index.php?p=vt&tid=451008
21st May, 2012 at 08:33:14pm
21st May, 2012 at 08:34:30pm
On 21st May, 2012 Sprocket said:
^^ Looks better simplify it a little. The switching circuit, take the live from the fused battery supply, and connect it to the relay coil( simple small loop at the relay). Then switch the ground for the coil. Less wiring ![]() My 79 Clubman Build Thread - http://www.turbominis.co.uk/forums/index.php?p=vt&tid=451008
21st May, 2012 at 08:34:31pm
21st May, 2012 at 08:34:53pm
awe crap, its lamps, you want to take the switching live from the high beam live, but still switch the ground On 26th Oct, 2004 TurboDave16v said:
21st May, 2012 at 08:44:12pm
Would that mean the lamps would only work with the High Beam ON ?
awe crap, its lamps, you want to take the switching live from the high beam live, but still switch the ground Edited by Wile E. Coyote on 21st May, 2012. My 79 Clubman Build Thread - http://www.turbominis.co.uk/forums/index.php?p=vt&tid=451008
21st May, 2012 at 09:02:34pm
On 21st May, 2012 Wile E. Coyote said:
Would that mean the lamps would only work with High Beam ON ? On 21st May, 2012 Sprocket said: awe crap, its lamps, you want to take the switching live from the high beam live, but still switch the ground Yes, but I have just read the topic in its entirety, so take the live from where you want to, ideally something that will be off when the key is removed. I'm forgetting myself and i've wired up lamps many times. 55w bulbs going to be enough?
21st May, 2012 at 09:11:56pm
Revised drawing as per your Edited comment, is this what you meant ? My 79 Clubman Build Thread - http://www.turbominis.co.uk/forums/index.php?p=vt&tid=451008
21st May, 2012 at 09:23:32pm
Thanks Sprocket, so now the question is what cable to use ? My 79 Clubman Build Thread - http://www.turbominis.co.uk/forums/index.php?p=vt&tid=451008
21st May, 2012 at 09:24:38pm
55w for the bulbs.... Not sure but it has to be better than what is on it currently My 79 Clubman Build Thread - http://www.turbominis.co.uk/forums/index.php?p=vt&tid=451008
21st May, 2012 at 09:31:01pm
thats exactly what I was thinking. This circuit will allow you to turn the lamps on whenever you want, just be sure not to leave them on, with a 30a drain the battery will be flat in no time.
21st May, 2012 at 09:39:19pm
thats exactly what I was thinking. This circuit will allow you to turn the lamps on whenever you want, just be sure not to leave them on, with a 30a drain the battery will be flat in no time. With switching the ground, you only need to find a local ground at the switch and run one wire from each switch from inside the car, or what ever, and with taking the live from the fused side of the battery fed, if anything shorts it is all protected. Obviously install the fuse as close to the battery as you can. The loop wire only needs to jump from 30 to 85 with about a 6" long wire terminated in the same crimp. My 79 Clubman Build Thread - http://www.turbominis.co.uk/forums/index.php?p=vt&tid=451008
21st May, 2012 at 10:09:32pm
Thanks Sprocket, so now the question is what cable to use ? That polevot web site suggests current ratings for their wire. with 4 lamps at 55 watts, you should expect about 18a, so you'd want a 20 amp blade fuse for your first bank of four lamps with a something like a 25a wire daisy chained from the from the fuse through the relay to the lamps, and a 10a fuse and 12a wire for the other two lamps in similar fashion. I'd suggest something like 40a for the unprotected wire from the battery to the fuse for both relays irrespective (the shorter the better). The switching wires do not need to be huge 10a wire is more than adequate Also remember that the ground wires needs to be equally able to draw the current, so make sure you size those accordingly. Normlly with spot lights they ground through the body if they are metal, but I'd always add a ground wire to each lamp fixing or its own ground wire of at least the current draw of the bubs fitted. You could probibly get away with lower rated wires, but me personally I don't risk it. I always like to see a good margin between the wire rating and fuse rating, especially when using 130watt bulbs
