Home > Help Needed / General Tech Chat > compression and c/r ?
eden7842
Member #: 8852
leicestershire
Is there any calculasion between the 2. So say if u had a 8.5 c/r when you built it and ran a comp test you should know wat the compression should be. Or vice-versa?
If that made scense
jamie@thefatgarage
Member #: 9345
Sheffield
I suppose in theory there would be a relationship between the two. You could work it out with a bit of maths if you assumed a perfect seal.
jlay
Member #: 1742
essex
but compression is also efected by cam overlap timing etc
My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901
wez
Member #: 9271
Stoke on Trent
it will only relate to the dynamic compression at what revs the starter turns the engine over at, not the static c/r
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
you need to work out the dynamic compression ratio to get an idea of this,
this sheet will help with that...
http://www.projectpontiac.com/ppsite15/com...atio-calculator
after that times the dunamic ratio by 14.7 to get a theoretical psi... however this dosent account for heat so the figure will seem very low.
