| Home > Help Needed / General Tech Chat > Minispeed Trigger Wheel | |||||||
1171 Posts Member #: 107 Post Whore Sunny Sussex |
16th May, 2005 at 11:19:30pm
picked up a nice trigger wheel from minispeed at L2B, it bolts onto the end of the crank pulley, i'll take a pic so u can see tomorrow. Edited by Mike on 16th May, 2005.
146 Posts Member #: 350 Turboing minis since '89 Supercharging minis since '04 |
17th May, 2005 at 11:04:27am
hi,
17th May, 2005 at 11:10:07am
trigger for what? never heard of it. Best 1/4 mile 13.2 seconds @116 mph
17th May, 2005 at 11:14:38am
here it is...
17th May, 2005 at 02:54:00pm
On 17/05/2005 11:10:07 Miniwilliams said:
trigger for what? never heard of it. trigger wheel for a crank sensor, although you've probably realised that by now :)
17th May, 2005 at 03:36:49pm
Nice bit of kit mike
17th May, 2005 at 03:44:17pm
well, before i get flamed for paying what i did.. i needed one quick with no work required to make one etc etc as i just dont have the time. I also got included with it an nice billet crank sensor adaptor that bolts onto the timing cover, and is fully adjustable. £100
17th May, 2005 at 04:48:10pm
Ouch!
17th May, 2005 at 09:20:04pm
Not easy to put on an A-series pully mind!
17th May, 2005 at 09:24:07pm
y i'd loctite the bolt in, i was playing with the wheel this eve and found out that the outer ring, the one thats got the cut out in it is actually on a thread, just bloody stiff, so using a C spanner u can tighten it and clamp the wheel in position - sorted.
18th May, 2005 at 12:57:18am
i asume thats so you can make it lign up with TDC ? as every setup would be different. TBO its worth the money paid, think how long it'd take to fabricate somethign as "trick" turbo 16v k-series 11.9@118.9 :)
18th May, 2005 at 09:32:51am
y its for adjustment, with the megasquirt u need to have the missing tooth 90 degrees before the crank sensor at tdc.
18th May, 2005 at 11:41:11am
looks good i see it's for running some different igniton:) Best 1/4 mile 13.2 seconds @116 mph
18th May, 2005 at 11:46:08am
With the Emerald ECU, you can have the missing tooth anyway, and just set a reference point in the software, can you not do this with the Megasquirt software On 15th May, 2009 TurboDave said:
18th May, 2005 at 11:48:14am
from what i have read, its 90 degs, could be wrong. i'll read it again lol
18th May, 2005 at 09:12:11pm
From what i hear AlexF is doing a MegaJolt mapped ignition setup also.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
18th May, 2005 at 09:25:18pm
is modifying the original damper really work, after all its rubber damped y? so the toothed section could move separate from the other? or at least you'd get some spark jump?
18th May, 2005 at 09:37:39pm
I'm currently running this setup with a Lumenition ECU and on the rollers haven’t noticed any spark scatter plus under acceleration it would retard the timing a nats ass if anything.
18th May, 2005 at 10:23:03pm
Someone's got CAD Edited by turbodave16v on 18th May, 2005. On 17th Nov, 2014 Tom Fenton said:
18th May, 2005 at 10:47:00pm
looks like autodesk inventor to me :)
18th May, 2005 at 10:59:50pm
It's all the same kinda boring stuff, you just drive them differently!
19th May, 2005 at 01:58:26am
On 18/05/2005 21:25:18 Mike said:
y What does that meen? turbo 16v k-series 11.9@118.9 :)
19th May, 2005 at 08:37:05am
I have fitted ford siera timing wheels to 3 mini pullies now and all have worked fine. I think the amount the damper moves is insignificant.
http://www.twin-turbo.co.uk
19th May, 2005 at 09:28:00am
y What does that meen? means yes, as in ... "after all its rubber damped yes?" and y ben, i'm using the EDIS4 pack, hense the 90 degs, thought i had read it right.
19th May, 2005 at 04:12:26pm
so you put the missing tooth 90deg before tdc?
