| Home > Help Needed / General Tech Chat > HIF 44 Carb rebuild for ERA Mini Turbo | |||||||
45 Posts Member #: 9406 Member Tadley, Hampshire. |
22nd May, 2012 at 12:59:00pm
I have purchased the Burlen fuels rebuild kit and having read their BRIEF instructions I sought out the legendary guide written by Tom Fenton
22nd May, 2012 at 01:20:30pm
Just use the original butterfly on the new spindle as you suggest. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
22nd May, 2012 at 03:59:00pm
As Wil says. Take special care fitting it though, as although it looks like a disc with square sides, they are not, they have a taper to allow it to fit snug into the bore.
22nd May, 2012 at 04:18:26pm
Thank you Tom & Will!
28th May, 2012 at 09:25:33am
well that went pretty well except for those darn springs and trying to get the lower right hand nut done up with the choke cam and heat shield in the way.
28th May, 2012 at 10:24:50am
Just had another look at the pictures associated with the rebuild thread and the diamond washer IS shown under the spring coils - so covering the screw heads and NOT over the coils - is this correct?
28th May, 2012 at 03:54:08pm
On 28th May, 2012 ricsdad said:
the diamond washer IS shown under the spring coils - so covering the screw heads and NOT over the coils - is this correct? Yes, & regarding the choke seals they're not a thick as the ones that came fitted as standard for some reason, but they seem to work ok. |
28th May, 2012 at 04:21:20pm
Thank you Turbo Phil! I asked Burlen and they said look at our exploded parts list so I did! It didnt answer the diamond washers question but it did explain the difference to Haynes - apparently there was an early alternative choke assembly which does seem to show an extra seal at the end of the spindle. Perhaps the "o" rings swell up on contact with fuel...
