| Home > Help Needed / General Tech Chat > Bottom pulley | |||||||
327 Posts Member #: 1145 Senior Member North Wales |
22nd May, 2012 at 07:05:30pm
Im about to get the Megajolt setup but was wondering if i can use the Med s damper kit.???
22nd May, 2012 at 07:24:00pm
Iirc the kit comes with all the teeth and you have to remove the one you need removed, if you want easy speak to Tom about his machined pulleys and brackets i believe a few with megajolt are using these. Crystal Sound Audio said:
22nd May, 2012 at 07:40:36pm
ok bud. ill take this onboard. Going through my list-making sure i get the right stuff.thanks for your help |
23rd May, 2012 at 08:18:19am
Yes you can use the med one, I have their trigger wheel and sensor bracket, they come with all the teeth, just fit, mark the tooth, take off and grind off the tooth flush, I just used an angle grinder, thenjust stick a bit of black paint where you have ground, so it won't rust. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
