Home > Help Needed / General Tech Chat > Intermittent misfire - EDIS failure
steve1275
Member #: 951
Bromsgrove
This is the control unit for the coilpack.I experienced a progressive misfire,with the tacho also losing signal.Traced it to this unit and replaced it.Seems to be sensitive to heat,needs a good heat sink,and I've also been told to use a special gel between the unit and heat sink to improve heat transfer.Anyone had similar problems?
'Where does the engine go?'
Yes from the factory in oem cars they are sat on heat sinks for a reason
I've fixed mine direct to the bulkhead - I take it I should make up an aliminium plate to mount it to?
jlay
Member #: 1742
essex
on fiesta's earn't they screwed to the steel fire wall. never had heat transfer grease under any i removed. other cars ones do like vauxhal and even the metro amp's on the dizzys but never the edis's oh and they are painted where as with the others are raw alu on the back. but anything can help
My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901
Good en Steve. ........ heat sink should be fitted as a matter of corse now!
Edited by BENROSS on 24th May, 2012.
The fiesta mounts to a chunky part of the body as is the mini bulkhead it may well be good enough...but they are heat sensitive and cooling will only help
steve1275
Member #: 951
Bromsgrove
Thanks for the input.I have been running with an ally plate,but maybe too near the hot bits.Sounds like it's a non-mini problem if most of them use a bulkhead mount.
eden7842
Member #: 8852
leicestershire
Mines spaced off the bulk head atm. Best make a plate for it :-S
steve1275
Member #: 951
Bromsgrove
Still getting the odd misfire/loss of tacho feed with the new EDIS unit (now in cool place on ally plate with gel.Is there something I'm missing?
Check all the connections and plugs Steve, ... check the crank sensor is close to the pulley. And the crank pulley is not coming loose......
tadge44
Member #: 2500
Buckinghamshire
Steve, I had all these problems, as well documented on here.
I,m sure it was all down to poor connections, particularly the earth connections, which should all be common to all the MJ stuff.
I use a large ally plate to mounts EDIS, coil pack, etc etc etc.
The RC signal seems to be particularly sensitive and I have switched connections several times to get a consistent result.
steve1275
Member #: 951
Bromsgrove
Hi David,thanks for this,I am inclined to think a poor connection is involved,but that I probably goosed the original EDIS as well.The well known 2 problems syndrome.
My car ran like a bastard some times then fine at others. Turned out the crank sensor was knackered.
tadge44
Member #: 2500
Buckinghamshire
I dont think that a faulty crank sensor would affect the RC signal ?
steve1275
Member #: 951
Bromsgrove
Just been to Shakey for the day,7runs (crap times but that's another story) and the engine never missed a beat all day.
So I am inclined to think that I 'cooked' the EDIS unit where I had it located previously.
Ambients today around 26C but coolant max 92C,intercooler outlet 45C.*happy*
Edited by steve1275 on 25th May, 2012.
