Home > Beginners Tech > fiberglass front???
evilbutnice
Member #: 9174
colchester essex
hi all i was thinking about put a fiber glass front on to my mini as i have to replace the front end (yay) the question i am asking is what problems if any has ppl had etc?? or usefull tips / tricks
many thanks darren
Dr. jinG
Member #: 368
Roseville, CA (USA)
GFP/Fiberglass fronts are typically poor fit, and require some customizing to get everything looking really good. You'll also need to figure out a mounting system (front hinge, rear hinge, solid?). I've got a set of GoMini hinges that allow for hinging from the firewall and the entire front goes up and over the windshield. Not sure if those are around anymore, but they're nice. Of course, you need to figure out how to latch the front, then...
1967 Cooper 's' Turbo build @ www.drjing.com
