| Home > Help Needed / General Tech Chat > lenght | |||||||
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
17th May, 2005 at 05:56:37pm
does any one know if there is a difference between the driveshafts off a drum and the driveshafts off a disc set up eg drum being shorter cheers "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
17th May, 2005 at 06:15:46pm
No they are the same. The only difference is the outer cv joint is larger on the disc setup, but the splines are the same so the cv's are interchangeable between the shafts (which are the same)
17th May, 2005 at 10:21:41pm
so can you think of why my drive shafts are too short then. measured my other mini from certain pionts and they are both he same part from the drive shafts, i am at a loss "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
17th May, 2005 at 10:41:28pm
How long is a piece of string....
17th May, 2005 at 11:07:22pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=4689
18th May, 2005 at 07:03:22pm
my ride hight is so the drive shafts are just about level, i have a subframe off a 77 with all the gear on it that came with it, and the hubs are off a late 84 mini, phoned people from mini sport and they said to put the drive shaft onto the pot first then put the pot joint into the gear box, what difference would this make "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
18th May, 2005 at 10:37:52pm
Are you saying the balls on the pot-joint spiders don't even reach the pot itself? or that they don't go all the way in?
Edited by turbodave16v on 18th May, 2005. On 17th Nov, 2014 Tom Fenton said:
19th May, 2005 at 06:04:12pm
im saying that they only just sit on the outside of the pot joint, guna go measure them up now as the lenght has been put on here so i can go see if they are the right lenght "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
19th May, 2005 at 09:12:51pm
ok right i measured the drive shaft and they are the right lenght, which is good as i dont have to look for other ones. what would be the next thing if i put 1.5 degree bottom arms on would this make a large difference to how far the joint sat in the pot, also how would this affect the handling of the car.
19th May, 2005 at 09:24:27pm
1.5 neg arms make bottom of wheels out further so make it worse
19th May, 2005 at 09:26:52pm
there not ment to sit out that far though are they "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
19th May, 2005 at 09:26:54pm
ha ha ha!
19th May, 2005 at 09:56:43pm
engine mounts and subframe standard, this is the one thats still in the pot joint its the shorter drive shaft, only thing i can think would be suspect would be the hubs but they are off a mini cause of the ball joints, tell tale sign between metro and mini eg mini ball joints screw on to the hub. thinking of using metro drive shafts as they are 40 mil longer so might just fit in there. this one seems like a new thing to me as no one knows why this is happening "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
19th May, 2005 at 09:59:52pm
I thought very early metro hubs had mini type joints but differant geometry
19th May, 2005 at 10:06:31pm
well if any one knows then this might be why its doing this but i dont know about metties really
19th May, 2005 at 10:10:09pm
early metro ball joints had a different taper, that's all.
19th May, 2005 at 10:15:17pm
ye the ones that came with the original car, different pots as they came off the metro with the engine but they are all the same arnt they none are longer then others "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
19th May, 2005 at 11:07:20pm
well there is a difference actually - some are a smaller dia than others - but no idea about a length difference. On 17th Nov, 2014 Tom Fenton said:
