Home > Help Needed / General Tech Chat > coilover help
jameswildcooper
Member #: 1355
Leicester
basicly up front Im running spax coilovers and there wound right down but i still can't get the front low enough.
I've put them on the softest setting also hoping they would come down a bit but they havnt.
i know there is different spring ratings and if i remember right i bought fairly hard springs before as i went down the Honda route at first before going back A series. could the harder spring rating be the problem?
the back sits nicely on protecs its just the front Im having trouble with *frown*
help plz lol
Edited by jameswildcooper on 25th May, 2012.
Chalkie
Member #: 9764
Northamptonshire.
Has it got the engine in? they might need to settle in
unless i am mistaken the honda engine/drivetrain is lighter that a mini's?
have you looked for lowered coilover mounts... basically it mounts the top of the coil overs higher up
408.Luke
Member #: 9909
Tyler, Texas
Adjusting your shocks wont change anything, sounds like you need to come down on spring rate. On a 5" shock (12" spring) i like to run 1" to a 1 1/2" of pre-load, this is for general coil over application not mini specific, havent converted mine yet so no hands on with a mini.
Edited by 408.Luke on 26th May, 2012.
-1974 Mini 1000 - BRG Turbo Build Soon to come
-04.5 LLY Duramax - RC/LB - White - Built Trans - EFILive - Dropped 4/6
-2013 TDI Passat - SEL - White - Lowered on Coilovers - Daily Driver
-2003 Silverado SS - 408 Stroker - DP NO2 - Full Suspension ~900hp For Sale
jameswildcooper
Member #: 1355
Leicester
yes engine was put in a few days ago.
not looked for different brackets yet.
i might try different springs.
i cant remember off the top of my head what rating i bought :(
jameswildcooper
Member #: 1355
Leicester
ok so ive bought 2" smaller springs....lets see how we get on now when they arrive
