Home > Help Needed / General Tech Chat > quick smoking question
eden7842
Member #: 8852
leicestershire
the misses car smokes like a chiminy when you go over around half throttle,
i beleve that there is a small score in one of the bores, would this cause this or would that make its smoke all the time?
my other though is that its running stupid rich over half throttle, (but obv this is more of a prayer)
cheers eden
is it diesel?
eden7842
Member #: 8852
leicestershire
1275 mini, shoulda said.
Its leakin oil out the back of the head gasket too :-S
are the breathers fed back into the carbs like the standard setup?
just a wild stab in the dark, head gasket gone into the pushrod holes..would cause the crank case to throw alot of shit into the breathers and could explain the oil leak down the back of the block
eden7842
Member #: 8852
leicestershire
Well we made the 80 mile round trip and it was shocking,
Brett, no there no fed into the carb
The car runs like a dream to be fair, just throws some oil onto the mani and some out the exhaust.
And would not stay cool at all so I wil do a comp test and go from there
