| Home > General Chat > Warped vented disc? | |||||||
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
27th May, 2012 at 03:02:33pm
I've got the Mini Sport - 8.4'' Vented Brake Caliper Kit and have a bit of s shudder under breaking.
27th May, 2012 at 03:05:04pm
I had a really bad wobble under braking on my old mini. Flange bolts had come loose. :$ On 11th Feb, 2015 robert said:
27th May, 2012 at 04:12:43pm
Take off the wheel and measure the run out with a dial gauge I seriously doubt it! |
27th May, 2012 at 05:08:25pm
Thats not unusual - the ventilated discs on my car also warped. |
27th May, 2012 at 06:42:08pm
ive had pad material fuse to the disc when I was was using green stuff and they got too hot..
27th May, 2012 at 08:01:42pm
Get them warm then give them a really really good stand on and get them red hot.
![]() 553 Posts Member #: 1356 Post Whore TRURO, CORNWALL |
27th May, 2012 at 11:39:58pm
If you can visually notice that the disk is running out then that is it. Maybe your drive flange is not running true and warped your disc or your disc is warped for other reasons such as incorrect fitment. Checking run out of both drive flange and disc with a dial gauge will reveal the culprit. Don't waste your cash just fitting a new disc without dial gauging it as you may well just warp another disc. |
28th May, 2012 at 07:51:57am
loose bolts have simulated this in the past; also check there is no build up of crap between the disc and drive flange mating surfaces |
28th May, 2012 at 07:55:37am
Cheers chaps, i'll get the dial gauge out this evening and check everything over.
28th May, 2012 at 08:02:48am
there may be some wobble however the clamping of the brakes would exagerate it |
28th May, 2012 at 07:43:00pm
dial gauge on the disc, 1.8mm movement.
