| Home > General Chat > things to drill holes with | |||||||
27th May, 2012 at 07:32:28pm
My qestion is what do you guys use? I have a week off in two weeks time so i would like to get cutting hehe!
27th May, 2012 at 07:43:34pm
I use step drills all the time for metal, mostly for sheet ally, but they will do steel, just make sure you keep stuff cool, iVE USED A 30-40MM one in a lathe to make my inlet runners from solid bar!
27th May, 2012 at 08:20:01pm
i use bosch hole saws, excellent on everything but stainless steel
Edited by Brett on 27th May, 2012. Yes i moved to the darkside |
![]() 324 Posts Member #: 9441 Senior Member South Devon |
27th May, 2012 at 08:36:03pm
We used step drill bits for smaller swages and starrett holes saws for larger swaged holes.
27th May, 2012 at 10:56:40pm
I used a step drill for routing cable through my shell and door for fitting central locking.
27th May, 2012 at 11:12:53pm
I have the bosh hole saws already, but due to having nothing to clamp the drill down with you get that slight wobble from where they clip into place, i did my subby and cross member with them, though i will be taking out the cross member and re-doing it with alot more holes and swags to keep it strong.
1391 Posts Member #: 1686 Post Whore Oxford |
27th May, 2012 at 11:42:12pm
I use these doo dars for sheet metal.
OMG Robert that's a big one |
28th May, 2012 at 08:13:38am
I use the hole shears sam linked to. there's a good link to them here:
28th May, 2012 at 08:55:28am
I've just picked up a set of cone drills from B&Q tradepoint; they don't have the steps in them so are a contunuously variable. Great for what i wanted but not so good if you want to keep everything to the same size |
