| Home > General Chat > mot and emmisions | |||||||
28th May, 2012 at 06:44:25pm
How do you lot get yours to pass?
13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
28th May, 2012 at 06:50:27pm
Tune it On 26th Oct, 2004 TurboDave16v said:
28th May, 2012 at 06:55:59pm
I thought that was the case 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
28th May, 2012 at 07:17:39pm
If its at 7%, it is too rich to pass a limit of 3% or 4.5% depending on the age. the basics of it means that the carb needs tuning to get it to pass. You need also be sure that the engine has been serviced as well. Old fuel won't help either.
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
28th May, 2012 at 07:36:30pm
On 28th May, 2012 eden7842 said:
How do you lot get yours to pass? put the probe in the car thats parked alongside the mini |
28th May, 2012 at 08:32:58pm
Its all down to the tune and how clean the burn is mine almost scraped through at a cat test standard
Edited by Brett on 28th May, 2012. Yes i moved to the darkside |
28th May, 2012 at 08:48:19pm
Find a sympathetic tester. On 26th Jan, 2012 Tom Fenton said:
28th May, 2012 at 09:05:14pm
On 28th May, 2012 Carlzilla said:
Find a sympathetic tester. At 7% not even a sympathetic tester should pass it. It is too rich to be doing any good to the engine anyway On 26th Oct, 2004 TurboDave16v said:
28th May, 2012 at 11:15:14pm
fit a modern engine .. mine sails through. turbo 16v k-series 11.9@118.9 :)
29th May, 2012 at 06:30:13am
Put a 'Q' plate on, visual only.
![]() 580 Posts Member #: 9580 Post Whore Surrey |
29th May, 2012 at 06:53:11am
Its an average reading so we tested for half the time in the exhaust and half the time on the floor and it got a pass (as an average). |
29th May, 2012 at 08:30:41am
I best get tweeking then sounds like it should easilly go through 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
![]() 392 Posts Member #: 5702 Senior Member Cornwall |
29th May, 2012 at 08:44:19am
Do you have an AFR gauge? |
29th May, 2012 at 08:59:02am
Pull the vacume pipe off the manifold so it goes lean, the one that supports the distributor or used to, if you have megajolt? Adjust tick over to suit, if will piss through
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
29th May, 2012 at 09:00:21am
buy a private reg that makes the car look older so the MOT guy goes on the old emissions? On 10th Mar, 2012 theoneeyedlizard said:
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
29th May, 2012 at 09:17:31am
that's fine until he puts the reg into the computer and it tells him what year it is and what level to test it to On 11th Feb, 2015 robert said:
29th May, 2012 at 09:31:09am
![]() 460 Posts Member #: 843 Senior Member Stoke-on-Trent. Duck. |
29th May, 2012 at 11:39:21am
All vehicles Pre 1st August 1975 - Visual Only ()
