Home > Help Needed / General Tech Chat > immobilizer removal?
shaggy591a
Member #: 9624
Seattle, WA USA
I have a laserline 921k immobilize installed on my clubman I want to remove. Can I just cut the lines to the box? And If I do that will it cause any problems?
1991 mini cooper
1971 mini clubman
without any knowledge of that system or what it actually immobilises, i would suggest tracing the wires to/from it and when you get to the ignition barrel or the coil or what ever you will see where the cuts were made in the loom
you'd need to trace the wiring and restore the immobilised circuits. Should be easy enough in a mini
