| Home > Help Needed / General Tech Chat > Up the boost at the touch of a button? | |||||||
![]() 644 Posts Member #: 9371 Post Whore East Yorkshire |
2nd Jun, 2012 at 04:53:06pm
I've seen this fitted to a few cars now and was wondering how you can up the boost at the touch of a button. I recently bought a bleed valve to do that job but I would like to have have 2 pre set boost settings
BHP sells engines, but Torque wins races! |
2nd Jun, 2012 at 04:57:17pm
Piece of pipe off the 3rd leg on the bleed valve, with a 12v solenoid valve on the end wired to a switch, valve closed it will run actuator boost, flick the switch to open the valve, it will bleed the air off to what ever the bleed valve is set too.
Edited by bennyy on 2nd Jun, 2012. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
2nd Jun, 2012 at 06:04:18pm
And you will need to fuel for the high boost all the time making it rather rich on low boost Yes i moved to the darkside |
272 Posts Member #: 9125 Senior Member Sheffield, South Yorkshire |
2nd Jun, 2012 at 06:40:37pm
maybe a stupid question but could you run somthing like a modern day "sport" button in the car that is linked to MJ and will change to anoher pre-set map which is designed for the higher boost? The turbo build has finally started |
2nd Jun, 2012 at 07:17:03pm
Profec g ready, or all will be revealed. When you come see me at the benross HQ
2nd Jun, 2012 at 07:17:48pm
You can switch maps but that has nothing to do woth the fueling. Audi s4 b5 - 470bhp & 486ft lbs
2nd Jun, 2012 at 08:08:01pm
Nice one, thanks a lot guys. It all makes sense now. Will take a look at Benross HG too... Can't think of a more exciting day out. BHP sells engines, but Torque wins races! |
2nd Jun, 2012 at 08:10:38pm
On 2nd Jun, 2012 madonminis said:
like to have have 2 pre set boost settings Road (14psi) and overtake the twat in the beemer (300psi) 300psi
2nd Jun, 2012 at 09:34:07pm
like to have have 2 pre set boost settings Road (14psi) and overtake the twat in the beemer (300psi) 300psi ![]() I'd go 500psi if i thought it could take it, but have to keep remembering its an A-series LOL BHP sells engines, but Torque wins races! |
2nd Jun, 2012 at 11:00:22pm
Why not wire up the original Metro Turbo solenoid, a simple cockpit mounted switch can open & close it to vary boost. Simple & cheap. |
3rd Jun, 2012 at 07:54:56am
On 2nd Jun, 2012 Turbo Phil said:
Why not wire up the original Metro Turbo solenoid, a simple cockpit mounted switch can open & close it to vary boost. Simple & cheap. I will probably do this as I have a couple of those solenoids kicking around somewhere BHP sells engines, but Torque wins races! |
3rd Jun, 2012 at 08:09:34am
put one in the part throttle lean of as well, on the same switch. On 11th Feb, 2015 robert said:
3rd Jun, 2012 at 09:25:51am
I have read that the metro turbo valve will only flow enough to bleed of 4psi.
3rd Jun, 2012 at 09:53:48am
the part throttle will richen up the off-boost/ non full throttle area though, and the metro valve aint bad tbh, mine will go from 4psi- about 8 ish with no restrictor Yes i moved to the darkside |
3rd Jun, 2012 at 08:49:39pm
I use the metro anti run on valve and it goes 7 -16 psi at the flick of a switch |
4th Jun, 2012 at 07:36:50am
Metro turbo solenoid will flow plenty, especially if you fit a restrictor in the bleed line.
4th Jun, 2012 at 07:53:16am
You can adjust your afr with a pitot tube to correct your fueling, getting rid of the resctrictor ring will also free up a couple of psi.. simple, cheap and efficient tune.
On 2nd Jun, 2012 Brett said:
And you will need to fuel for the high boost all the time making it rather rich on low boost |
4th Jun, 2012 at 08:04:41am
4th Jun, 2012 at 08:06:49am
Here's what I was going on...
On 7th May, 2008 Jimster said:
the std metro item only bleeds 4psi. I use to use a few of these for stage boost each one coming on giving me 4psi extra boost, worked well, but they are a bit heavy Audi s4 b5 - 470bhp & 486ft lbs
4th Jun, 2012 at 08:18:11am
soccer over the tunel
On 4th Jun, 2012 apbellamy said:
What's football? |
