| Home > Help Needed / General Tech Chat > smoking from the breathers | |||||||
![]() 1014 Posts Member #: 238 Post Whore essex |
2nd Jun, 2012 at 08:32:52pm
I'm led to believe that smoking from the breathers is a piston ring issue, I've done a compression test and this reveals that cylinder 2 is the problem..I then put oil down the bore and I got a higher compression result.
2nd Jun, 2012 at 08:44:40pm
Consider new pistons. A well used standard block will be worn beyond just a re ring. Take the head off an inspect it before you spend £100 on rings you wont be able to use On 26th Oct, 2004 TurboDave16v said:
3rd Jun, 2012 at 07:56:50am
I would just get these while they are such a bargain
3rd Jun, 2012 at 08:33:36am
I would go for new pistons and a rebore, job done then, plus 20 omegas with 10cc dish
4th Jun, 2012 at 08:20:35am
Looks like I need to pull the engine out and strip it down. ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
4th Jun, 2012 at 07:14:54pm
Took the engine back out today, stripped it down, found a damaged piston! ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
