| Home > Help Needed / General Tech Chat > Engine Questions. | |||||||
5th Jun, 2012 at 08:53:05am
Hey guys right question time.
5th Jun, 2012 at 08:59:48am
do you know what the chamber sizes are in the head now? |
5th Jun, 2012 at 09:00:35am
I need to get a cylinder head to be honest my mate had my old one off me but it should be standard 940 size |
![]() 883 Posts Member #: 9774 Post Whore Buckinghamshire |
5th Jun, 2012 at 09:10:03am
Central oil pick up is definitely worth doing.
http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
5th Jun, 2012 at 09:17:06am
Std oil pump will be fine. If its in gd nick obviously 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
5th Jun, 2012 at 09:26:14am
if its of help, I ran a 1100 with a 295 head and MG cam, 3.7 diff on 10's; cracking engine for what it was (thrown together!). I used the standard pump (suited the cam i was using).
5th Jun, 2012 at 10:03:24am
Id buy a new pump binned my old one
![]() 4641 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
5th Jun, 2012 at 10:18:10am
The 940 chambers {21.4cc nominal} are smaller than the 998 head chambers {24.5cc nominal} so fitting the 940 will raise the compression if the chambers are standard. |
5th Jun, 2012 at 10:19:39am
So no need for a head skim or block skim?
5th Jun, 2012 at 11:24:04am
5th Jun, 2012 at 11:39:31am
Roughly 1cc iirc. |
5th Jun, 2012 at 11:42:34am
This how to create the pockets... if you are brave...
5th Jun, 2012 at 11:45:31am
I have a tech drawing for doing the pockets so coud use a milling machine.
5th Jun, 2012 at 12:32:42pm
I think that is our very own Robert in the video |
5th Jun, 2012 at 12:55:27pm
5th Jun, 2012 at 01:06:28pm
Did ir work though? |
5th Jun, 2012 at 01:34:52pm
I'm sure there are a few that have cut the pockets this way |
5th Jun, 2012 at 01:59:14pm
Ohh right Hmm could just send it to my old work though to have it done :) |
5th Jun, 2012 at 03:32:06pm
whats sw5 came like? |
5th Jun, 2012 at 08:42:47pm
On 5th Jun, 2012 RidingLow said:
whats sw5 came like? A metal stick with bumps on it.
5th Jun, 2012 at 08:46:11pm
whats sw5 came like? A metal stick with bumps on it. ![]() Well I asked for that :$ I ment as a daily cam :) like drive abilty and stuff |
5th Jun, 2012 at 08:53:47pm
i cut my pockets that way too, but i sleeved over the drill with a pvc pipe so the cutter only came out of the pipe the depth of the cut. this meant i could lean heavy on the pipe so it would cut and not jump up and wander across the block face. not ideal certainly, but worked a blooming treat :) turbo 16v k-series 11.9@118.9 :)
5th Jun, 2012 at 09:12:44pm
Ohh why is everyone being hero's when doing this mod haha thanks :) may look into doing it |
319 Posts Member #: 1742 Senior Member essex |
5th Jun, 2012 at 09:46:44pm
i did it by hand with an air die grinder and burrs. I would deck the block to at least clean the surface up if your going to use the 12g940 head as on my small bore there was a water way that pitted the block slightly but this is where cylinder 2 and 3 fire rings seal. personally i like to bring the pistons level with the block to narrow down the squish band but this is one of those subjects that people seem to differ on. My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901 |
![]() 6753 Posts Member #: 828 Post Whore uranus |
6th Jun, 2012 at 06:19:37am
hi stephen ,
