| Home > Help Needed / General Tech Chat > Spherical bearing in rod change yoke. | |||||||
5th Jun, 2012 at 05:28:02pm
As above has anybody carried out this modification? I want to remove the play between the yoke and the gearstick. I've had a search but can't find any info. I take it that I remove the ball from the gearstick then find a bearing the correct size and machine the yoke for it to fit in.
5th Jun, 2012 at 05:54:15pm
Ron, the yokes are weak enough without removing more material , if you think you have too much free paly between the two parts maybe look to make a new ball but you are always gonig to suffer with slack due to the nature of the design, you could try fitting a spherical bearing but then the free paly would be moved to the stick in the bearing bore,
5th Jun, 2012 at 06:06:33pm
Ditto what Carl says about the yoke being weak, I smashed one on the DON at Castle Combe a few years ago and had to go searching the autojumble for a massively overpriced scrap old rod change to pillage a yoke out of.
5th Jun, 2012 at 06:25:35pm
I found out the hard way how weak the yoke was when I stripped down the unit. The only yoke I had isn't the best, that's why there is so much play. I will pull it apart and see if I can measure up for a new ball on the gearstick. If not I will have to sort out a new yoke! |
5th Jun, 2012 at 06:31:59pm
how about replacing the ball with a threaded stub, and putting a rober on it and a nut at the bottom so you can compress the rubber so it expands to fill the yoke snugly. On 28th Aug, 2011 Kean said:
5th Jun, 2012 at 06:34:27pm
There is loads of play in the housing bushes that is easilly corrected.
5th Jun, 2012 at 06:46:37pm
I'm going to pull it apart tommorrow and see what I can sort out. I have already fitted a brass bush in the front of the housing to remove the play. I'm just trying to make the shift feel abit more positive. |
5th Jun, 2012 at 06:55:35pm
On 5th Jun, 2012 Tom Fenton said:
Ditto what Carl says about the yoke being weak, I smashed one on the DON at Castle Combe a few years ago and had to go searching the autojumble for a massively overpriced scrap old rod change to pillage a yoke out of. so one could say, the yoke's on you? 8-) turbo 16v k-series 11.9@118.9 :)
17th Jun, 2012 at 07:41:01pm
I finally got this sorted today! I managed to get a new yoke for the selector housing (cheers Eden) and fitted this today.
17th Jun, 2012 at 08:11:32pm
Glad its dun the job mate 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
