Home > General Chat > Any thoughts on price?
yellowmini
Member #: 9040
Worcester
time has come for me to sell my mini but am unsure what price to ask for if anyone has any input would be appreciated. Main thing to keep in mind, the 998 has thrown a rod and is the reason for selling it as iv got absolutely no money to fix it.
spec as follows:
1989 Mini Mayfair - G reg (filler free shell)
Solar Yellow Colour, Black group 5 Arches, White Fibreglass Bonnet (also have standard metal bonnet in yellow)
12x6 Minilight wheels
Front 2 degree camber
All braided break lines
Rear hi-lo’s fitted with new rubber cones (have front hi-lo’s but not fitted)
New heel board professionally fitted with new rear subframe and all new mounts
20 point adjustable Gaz shocks all round
Corbeau sprint drivers and Mamba passenger bucket seats (driver’s seat floor mounted, Passenger seat on subframe, also have driver side subframe)
Securon 4 point harnesses for driver and passenger (standard rear seat not fitted but own)
Steering column drop bracket
Mountney Leather Steering wheel (also have standard wheel and Alpha quick release D shape suede wheel)
Aluminium finish dashboard with standard 3 clocks
All sound deadening and rear carpet removed but still have
Alloy interior door handles
2 speakers in rear parcel shelf + 2 speakers fitted into dash instead of fresh air vents
CD player with IPod connection fitted into dash
Solid mounted Front subframe
Facet Electric Fuel Pump (not fitted)
Engine Spec:
998cc block pocketed
Morespeed “stage 3” 1275cc head
LCB exhaust manifold
Centre exit RC40 exhaust
HIF44 carb
K&N cone air filter
Flat top 998 pistons
Duplex timing chain
Straight cut drop gears
Lightened MED flywheel with new clutch fitted (done 350 miles)
276 fast road Kent cam (2k-7k rpm power band)
Standard 998 gearbox with 3.44 Final Drive
All ancillaries with it
Also have standard 1275 metro engine (minus ancillaries which were used with 998 engine)
(Its the yellow one in the picture)
As it's a non-runner, my first question would be, how much MOT left - it gives a good idea if it's really worth repairing.
If it has "thrown a rod", how much other internal damage ?
Beyond that, probably worth more broken and parts sold seperately.
yellowmini
Member #: 9040
Worcester
its got MoT till march and tax still on it too till end of august. as for internal damage its unknown. though has the other engine with it if someone wanted to change them over itd be ready to go again.
i doubt you will get much as a non runner £700-1k tops would be my guess, far better to bit the bullet fix it and then sell
Craigie-B
Member #: 9468
Wootton Bassett
give you 400 tomorrow for it
yellowmini
Member #: 9040
Worcester
alternatively if i get it back to running with identical spec what you reckon its worth?
Why not drop the 1275 in it? Would fetch far more like that.
£1500-£1700 tops
Sounds harsh but i dont see much of a market for minis at the moment, there almost a luxury second or weekend car these days.
Edited by wolfie on 6th Jun, 2012.
