Home > General Chat > Head casting numbers
eaton_mini
Member #: 1649
West Sussex - dreaming of forced induction!
Ok so i have a 12G202 head, but behind the thermostat housing it has '28L8' cast into it. Its not stamped, its raised, anyone shed any light on what it means?? Date stamp maybe??
Chalkie
Member #: 9764
Northamptonshire.
umber Inlet dia. Exhaust dia. Nominal cc Standard fitment
2A628 1.0625"/26.99 1.00"/25.4 24.5 850, 998 Mini & 948 Sprite
2A629 1.0625"/26.99 1.00"/25.4 24.5 948, A35 & Morris Minor
12A1456 1.0625"/26.99 1.00"/25.4 24.5 850, 998 Mini & 948 Sprite
12G202 1.156"/29.36 1.00"/25.4 26.1 997 Cooper, Austin 1100 Mk
CAM4180 1.0625"/26.99 1.00"/25.4 25.5 998 Mini - A+ (1980-on) and lead free
12G206 1.218"/30.93 1.00"/25.4 28.3 Early 998 Cooper, MG1100
12G295 1.218"/30.93 1.00"/25.4 28.3 998 Cooper, MG1100
12A185 1.401"/35.6 1.22"/31.0 21.4 First Mk1 Cooper S
AEG163 1.401"/35.6 1.22"/31.0 21.4 Later Mk1 & Mk2 Cooper S
12G940* 1.312"/33.33 1.15"/29.2 21.4 1275GT, Austin 1300, all late A+ models inc. Turbo but not MG Metro
12G940 1.401"/35.6 1.15"/29.2 21.4
Stamped '12G1805' on flat area by thermostat - MG1300, 1300GT & Mk3 Cooper S
12G940* 1.401"/35.6 1.15"/29.2 21.4 As above plus MG Metro
*Note:
A+ head castings - despite having the same 12G940 casting number - are considerably different in appearance, loosing the flat area behind the thermostat housing and around the rest of the rocker/head stud areas to a sculptured look - where these areas are replaced by a 'sunken' cast finish.
The A+ castings were introduced with the appearance of the Metro in 1980, although some late 1275GTs (1979-on) had them fitted. Generally they are easily recognised by their colour - a putrid yellow on the small-bore castings and bright red on the large-bore ones, a paint finish that is VERY difficult to remove, even in a chemical tank.
The MG Metro Turbo shares the same valve sizes with the other non-'big valve' 12G940 variants but has 8mm, sodium-filled exhaust valves.
A+ heads generally have three collet grooves in the valves, collets are 14-degree cone taper instead of the 10-degree on single groove collets (so parts are not interchangeable between single and triple groove types) and the top-caps have a raised ridge around the collet hole.
