Home > Technical Chat > AFR gauge
Double D
Member #: 8966
bedworth, warwickshire
Hello everyone not been on for a while.
Just wanted some info on getting my carb set up for the best AFR's. Am I right in thinking it is best to be around 10/11 on full boost then around 15ish when cruising with no boost.
Any help and comments on this would be great or even a link on the forum if this has already been discussed.
I have been through this with Dave who has the other turboed Austin but its gone totally out of my head!!!!!
Regards Dave.
tadge44
Member #: 2500
Buckinghamshire
Come on David, you must remember !
I reckon about 12 for full power and anything up to 17 for light cruise as long as it does not misfire.
As Dave said 12-1 is what you want under boost to be safe, no need to be any richer.
Double D
Member #: 8966
Thanks chaps gotta get it sorted soon, no probs at the mo but does use a bit to much fuel for my liking. And after that I'll treat it to some new stem seals and some rings if needed..
I knew you'd tell me off Dave...... Just to forgetful. Hows the bike tank looking have you done anything with it yet??
Thanks again.
