| Home > Help Needed / General Tech Chat > carbon fibre trimming tool | |||||||
756 Posts Member #: 1355 Post Whore Leicester |
17th Jun, 2012 at 06:36:01pm
as above really whats the best tool to use to trim down carbon fibre?
![]() 412 Posts Member #: 9766 Senior Member Warwickshire |
17th Jun, 2012 at 06:59:39pm
Angle grinder and a metal cutting disc 1mm thin jobbies or a grinding disc :) Avon 2010 class c 3rd
656 Posts Member #: 1917 AKA chargedzetec Milton Keynes |
17th Jun, 2012 at 07:03:19pm
Dremel with a cutting disc. That's what I use, and gives really clean, thin cuts. Wouldn't use anything else. This is FORD country, on a quiet day you can hear Vauxhalls rusting. |
17th Jun, 2012 at 07:03:20pm
ok sweet i was thinking nice sharp stanley knife and keep going over it lightly a few times till it cuts through completely..... |
17th Jun, 2012 at 07:04:03pm
ill have a go with cutting disc then :)
17th Jun, 2012 at 08:14:28pm
I used a dremel with a cutting disc when I had to cut tons off my Curley dash. |
18th Jun, 2012 at 08:00:25am
On 17th Jun, 2012 Turbo Phil said:
I used a dremel with a cutting disc when I had to cut tons off my Curley dash. Was your carbon fibre dash made of gold then if your cuttings tons off ;] |
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
18th Jun, 2012 at 08:38:26am
wear gloves mate, if you get carbon fibre splinters in you your body wont reject it as a foreign body so be careful :) Edited by Craigie-B on 18th Jun, 2012. On 10th Mar, 2012 theoneeyedlizard said:
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
1391 Posts Member #: 1686 Post Whore Oxford |
18th Jun, 2012 at 02:01:15pm
Permagrit blade in a jigsaw followed by permagrit files then wet and dry paper. On 19th Feb, 2011 Miniwilliams said:
OMG Robert that's a big one |
18th Jun, 2012 at 02:59:34pm
On 18th Jun, 2012 Craigie-B said:
wear gloves mate, if you get carbon fibre splinters in you your body wont reject it as a foreign body so be careful :) http://www.twin-turbo.co.uk
18th Jun, 2012 at 10:15:44pm
Its no wives tale, but you do need a split small enough. Either way when trimming up decent gloves, a decent mask and overalls are the way to go. Id even have a hoover on tap. My jigsaw has an attachment for it.
On 18th Jun, 2012 Ben H said:
Is that true or an old wives tale? Sounds like bunkum to me. On 18th Jun, 2012 Craigie-B said: wear gloves mate, if you get carbon fibre splinters in you your body wont reject it as a foreign body so be careful :) On 19th Feb, 2011 Miniwilliams said:
