| Home > Help Needed / General Tech Chat > dump valve | |||||||
621 Posts Member #: 393 Post Whore Oulton Park |
20th May, 2005 at 12:43:53pm
running my dump valve is it meant to be like this i've got it on a T in the line to the inner cooler near as i can to the carb and that seems ok but my bailys single piston type seems to be half open already when the car ticking over like theres to much presure pulling it open! the return i've got running onto the top of the inlet where someone told me to run it! is there to much presure there or is there a better place?? |
20th May, 2005 at 01:21:31pm
It should be open on tick over, if you have the twin piston dump valve the main piston will be up at tick over and the second piston (more like a little flap) will stay down which i like because it stops any crap going into the engine. The main piston will move down if the engine is revved, but be carefull of it sticking. I had to get a seal made from viton rubber to cure mine in the end. -MINI CLUBMAN 1380 TURBO- |
20th May, 2005 at 01:33:27pm
have i got the dump valve return going to the right place is that the usaual |
20th May, 2005 at 03:23:16pm
Zeemax its in the correct place buddy
22nd May, 2005 at 10:15:28am
i found out for myself and you can't run the boost gauge off the top of the inlet cos theres vacum there best T ing into the the platum chaber |
22nd May, 2005 at 10:45:40am
You can run the boost gauge off the inlet manifold. This will of course show vacuum, when there is vacuum. As soon as the engine comes on boost it will show boost, simple. |
22nd May, 2005 at 11:26:23am
yup, my boost gauge and dump valve trigger are both on the inlet manifold, luckilly it had 2 nipples on it when i got it :) On 20th Oct, 2015 Tom Fenton said:
22nd May, 2005 at 07:17:43pm
Can see if your driving with economy too if boost guage shows vacuum. Not that we should worry too much about economy -MINI CLUBMAN 1380 TURBO- |
