Home > Help Needed / General Tech Chat > Bearing puller
Mike-998
Member #: 9774
Buckinghamshire
Hit a bit of a wall with the project, need to remove the bearings from the output shafts, so I can stick them in the new diff.
Can anyone recomend any suitable bearing puller? I tried improvising with my flywheel puller but that didn't work.
Thanks,
Mike
Are you talking about the diff roller bearings?
You'll be luck to get used ones of in one piece.
I usually use a small balsa chisel to get the moving, then pry of with a pair of crowbars.
metroturbo
Member #: 989
North Yorkshire
This is the type of bearing puller you need. I'm sure that cheaper ones are available.
http://www.machinemart.co.uk/shop/product/...earing%20puller
Mike-998
Member #: 9774
Buckinghamshire
Thanks, I'll have a look on eBay
Managed to get enough of it off using a flywheel puller with head nuts on the end of the bolts to get at the crownwheel bolts. I still have the inner part of the bearing attached to the crown wheel, will try and get it off tomorrow
that's the bit I use a balsa chisel for.
Kean
Member #: 341
aka T2clubby
South Staffs
3 Leg puller and a blow torch every time, not destroyed one yet
I have a cheapo 3 leg puller that'll do it if needed.
I never use a puller on that one bearing. A pair of tyre levers works every time. Rest the cranked end of each lever on opposing chrownwheel bolt heads and under the inner bearing race (there's just enough overhang) then apply equal force to the two levers, and off it pops. It helps if you have the diff in a large bench vice so it doesn't skite across the garage.
I seem to always end up with crown wheels that have the inner race of the bearing welded to them...
Alex
Member #: 1851
Woolavington, Zummerzet
Putting a U-shaped exhaust clamp round the groove of the bearing gives you something substantial to pull on using a normal 3-legged puller.
Mike-998
Member #: 9774
Buckinghamshire
That's a good idea actually, I think the bearing puller I have might manage if I use a U clamp as well.
