Home > Help Needed / General Tech Chat > Off topic a far away but..
Chalkie
Member #: 9764
Northamptonshire.
Right guys
1993 Land rover 200 TDI what size turbo do they run?
and can it be adjusted?
also smokes alot on start up? read a few things online about adjusting the fuel pump but no 100% sure
thanks
stephen
don't expect alot of replies but turbo's a turbo :) well hope so...
1380rich
Member #: 9766
Warwickshire
I adjusted the pump and shortened the actuator rod .. Made hell of a difference on my 200 tdi with a bit of black smoke on full throttle but nothing major with an ally sport front mount intercooler. Not much help I know but it went real well after *happy*
Avon 2010 class c 3rd
eden7842
Member #: 8852
leicestershire
Ot a tad more but wuld this work on any deisel?
Chalkie
Member #: 9764
Northamptonshire.
ahh cool! my cousin has a 200 tdi and its a bit sluggish lately smokes a bit so was wondering if any little twicks could help it
and thanks man :)
No.
But what diesel do you have?
Edited by John on 21st Jun, 2012.
haimesyboi
Member #: 5702
Cornwall
If it has recently become sluggish, clean the inside of the intercooler out, check the lift pump is working, how much boost it is running, injector cleaner etc.
Chalkie
Member #: 9764
Northamptonshire.
Okay thanks :) ill take a look next week then as hes on night shift at the moment
Advantage
Member #: 1450
Near Paris - France
Newish diesel becoming sluggish is usually a cogged EGR valve.
Diesel engine need spirited driving once in a while. Not everybody does it.
Rusty by nature
Chalkie
Member #: 9764
Northamptonshire.
Oh he drives it as quick as he can giving it a boot full and it doe long runs to chick sands and woburn we live in kettering so good 50 off miles easy
100ev8
Member #: 9138
wolves
blank the EGR of with a nice bit of ally plate before you do anything . causes to much shit in the manifold and loads of probs when they stick open
http://www.fishfight.net/
Mine smokes a bit on startup, just an old landrover diesel engine!
You can shorten the actuator arm a bit. I've just been thinking about adding a bleed valve on my 300 as the actuator is inaccessible.
I wouldn't go more then 16psi though personally. If you do turn it up make sure you fit a decent intercooler and give the pump a tweek to supply some more fuel with the air to make it all worthwhile
Also turning the fuel diaphram 90 degrees makes a big difference on mine. Trouble is the temptation to keep turning it never goes away!
I'm gonna fit a bigger intercooler to mine, straight through exhaust and turn the boost to 16psi. It'll either go well or at 150k blow up so we'll see!
best_stig
Member #: 6449
Brisbane, Australia
Keep us posted, im tempted to turn up the boost on mine, but then id need to put a non-rusty radiator and probably put a bit of coolant in it for summer.
In boost we trust
Land rover TD4 intercoolers are huge and where pretty efficient on the upside down skip. should go straight in the earlier cars with a bit of fettle.
Chalkie
Member #: 9764
Northamptonshire.
Not any issues now a pipe had come loose and leaking also ran some injector cleaner through its good now :) thanks guys
