| Home > Help Needed / General Tech Chat > water pump and crank pulley alignment | |||||||
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
21st Jun, 2012 at 07:25:29am
i seem to be having difficulties getting my water pump and crank pulley to align for the fan belt if i use my orignial clubman water pump spacer the water pump pulley is far too much to the right (when looking in from the front)but in the correct possition for the fan and rad, if u use a small spacer the water pump pulley fowls the water pump and it too far to the left. are there any other sizes available inbetween the 4mm and 17mm spacers id cut mine down but dont have anything to make sure its 100% straight wouldnt want it to wobble and go through the ally rad. Edited by wng691s clubby on 21st Jun, 2012. Done now needs redoing lol |
21st Jun, 2012 at 07:41:12am
http://www.minispares.com/product/Classic/...g/PGX10001.aspx
21st Jun, 2012 at 07:54:51am
may just do the job Edited by wng691s clubby on 21st Jun, 2012. Done now needs redoing lol |
21st Jun, 2012 at 04:51:38pm
The pulley shouldn't need any spacers, they are to move the fan so go on the outside of the pulley.
21st Jun, 2012 at 07:13:34pm
The large water pump pulley fouls the head on a 998, other than that, either large or small pulley should both fit on any water pump without spacers. As said above, the spacers are to move the fan closer to the rad On 26th Oct, 2004 TurboDave16v said:
21st Jun, 2012 at 07:44:40pm
il have to have another look tomorrow after work cheers guys for the advice Done now needs redoing lol |
cheers in advance guys
