Home > General Chat > metro turbo to n/a
mercenary62
Member #: 9937
hi still a bit of a newbie ,so here goes ,im going to use my mini for hill climbs mainly and would like to run it on carbs can i use the metro turbo engine using a mg std metro cam ,in the turbo block ,also using the turbo head and crankshaft ,i know il need to change the pistons for std n/a items to increase compression ,il also be running split weber 45s and a straight cut box with salisbury lsd ,any ideas would be appreciated
Edited by mercenary62 on 22nd Jun, 2012.
give em hell
if you go to all that trouble engine all you have is an a+engine with a turbo crank.
With standard turbo pistons and 17cc in the head 10.5:1 compression is possible.
Why use a tame cam?
Edited by minimole23 on 22nd Jun, 2012.
standard MG Turbo engine is 9.4:1 CR and the pistons are tougher than standard. other than the crank and the valves that's the only difference from a standard engine.
oli79
Member #: 8480
I think you would need some serious head work to make use of split webbers, and I would have thought a much more aggresive cam, as a start are you aiming for a certain power figure?
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
Go Turbo its the way forward.
You'd be better off selling the splits & using the money to fund a decent cam & head.
haimesyboi
Member #: 5702
Cornwall
Sell and build a 998 turbo?
