Home > Help Needed / General Tech Chat > AN6 or AN8 Fittings for fuel
mini.cooper998
Member #: 3772
Wigan
hi all, im just about to order a fuel cell but it only has an AN6 fitting on the outlet and on the return. IS an AN6 fitting big egnough to supply fuel for a turbo conversion.
cheers
kcchan
Member #: 8853
AN-6 will be fine for the application
Yep -6 is fine
rick
mini.cooper998
Member #: 3772
Wigan
even up to 220bhp
mini.cooper998
Member #: 3772
Wigan
strange as i thought the feed line if done in copper should be 8mm
kcchan
Member #: 8853
-6 means that the pipe OD will be 6/16". The ID will vary depending on what type of hose you use but it'll probable be around 8mm.
jamie@thefatgarage
Member #: 9345
Sheffield
-6 is good for WAY more flow than you will ever need
Absolutely. Although if it is on the tank-pump side, I'd always prefer a larger hose so there is no risk ever that cavitation could occur at the pump.
From pump-engine -6 is more than adequate for any Mini.
mini.cooper998
Member #: 3772
Wigan
cheers all
