Home > Help Needed / General Tech Chat > rear shocker fitting.
1293 sprite
Member #: 5449
Melton Mowbray
Hi
I've rebuilt my rear subframe, its ready to be refitted except I've not ordered my rear shockers yet. Is it going to cause me problems if I fit the subframe first, then fit the shocks at a later date? Just concerned about the length of the lower shocker mounting stud. Id have thought you would be able to change a service item in situ, but thought id check.
thanks, James.
1293 88.8hp 82.2ftlb
17.3 1/4 @ 78 mph
Naturally Aspirated (for now)
Its not a problem to fit them later
1293 sprite
Member #: 5449
Melton Mowbray
Brilliant thanks, didn't want to kick myself if I had to drop it again!
17.3 1/4 @ 78 mph
Chalkie
Member #: 9764
Northamptonshire.
Mine is sat in the garden atm with no front shocks or cones in just 2 blocks of wood keeping front end up :) its fine for now just don't try drive it *happy*
kcchan
Member #: 8853
Just drop the radius arms, wiggle the damper on the stud, do the nut up, then raise it and do up the nut at the top.
Done it a fair few times.
