| Home > Help Needed / General Tech Chat > titanium heat resisting properties | |||||||
831 Posts Member #: 908 Post Whore gateshead |
24th Jun, 2012 at 12:46:37pm
how effective would it be on the bulkhead regarding heat to fasten some sheet titanium to it. got some lying about and the exhaust flange is sitting near it so was wondering if it would help.
balls to the blower!!!
24th Jun, 2012 at 12:51:21pm
What are you hoping to achieve?
I seriously doubt it! |
24th Jun, 2012 at 01:36:09pm
Ti has a much lower heat conductivity to alluminium, more in the region of steel and stainless, (according to the web)
24th Jun, 2012 at 07:10:48pm
Does it really matter? Heat shields are made from aluminium. Its the air gap that matters. So long as there is an air gap either side, it will act as a heat shield. On 26th Oct, 2004 TurboDave16v said:
24th Jun, 2012 at 10:01:30pm
righty. ok im with you. like i said, the exhaust outlet flange is only about 1" from the bulkhead so i was thinking of fixing some titanium sheet to that area on the bulkhead to stop the heat transfer. if i can get a gap between them it will work if i understand correct.
318 Posts Member #: 9408 Senior Member Tiptree, Essex |
25th Jun, 2012 at 09:31:30am
Polish the sheet before you fix it in place. www.topcatcustom.co.uk |
